-   -   GEEEZ, the coolant drain plug on the engine block is WAY up in there! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/58768-geeez-coolant-drain-plug-engine-block-way-up-there.html)
overkill 02-02-2002 08:07 AM
F that, I'm not going to do that yet! When I have my temp switch replaced then maybe ill do it, but then I thought why bother? I already emptied the RAD, so why dont I just fill the coolant RES with water then run the engine and have the water pump flush the engine block out and just keep empting out the RAD? Does that make sence?
P.S. I hope you guyz dont think im flooding your forum! I have porsche FEVER and its usually quiet in here anyway:D
AFJuvat 02-02-2002 04:26 PM
Depending on the condition/when your coolant was changed (should be in the maintenance records you got when you bought the car) you should be able to refill the radiator and reservoir, and bleed the system completely.
AFJuvat
