-   -   vibration - would appreciate your help! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/58778-vibration-would-appreciate-your-help.html)
macehammerman 02-02-2002 10:57 AM
Hi guys - I have an '86 951 with a vibration. I have replaced the clutch (Sach's spring) and all clutch components, new motor mounts, new tires, new balance shaft belt and timing belt (balance shaft is installed properly) and rebuilt the torque tube. But there is still a vibration, especially at around 3000 RPM. I am baffled!
Is this common with the '86 turbo? I drove an '83 944 for 10 years, and never had a problem like this. Any input is appreciated!
Terry
'86 951 Pearl White
'83 944 Pasdena Yellow
cruzermusic 02-02-2002 03:41 PM
did you check your trans? wheel bearings?
macehammerman 02-03-2002 08:39 PM
Yes, I did...everything was OK there -
Any other ideas?
Terry
