A non-running car is worth about $500. Even though it starts, it's still not worth more then that.
Dang, that's why I asked you where you were. . .saw this coming and am looking for another 944 Chump Car.
I'm in austin -- run a 924S Chumps Car -- paid $450 for it and that was running!!
Needed the clutch put in (new clutch came with car) rebuilding the top end will run at least $600 in parts and head/valve job work. that doesn't count the labor pulling the heads out and back in. I maybe interested in the car as is. How clean is the rest of the car? shoot me some pictures and we can talk email me at mike@lonestarrpm.com http://www.lonestarrpm.com Mike |
txhokie4life: I'll take pictures in a few days and send them to you. Getting too cold outside to work on the car.
I was trying to figure out how much rebuilding the head would cost. I called a top-notch machine shop in deep south Texas (Brownsville to be exact). I was told they would charge me between $200 to $300 for labor (they know my timing went out and valve(s) are bent). The valves are $17 per intake valve and $36 per exhaust valve. txhokie4life: When you say rebuilding the top end will run at least $600 in parts and head/valve job work, how much of that is labor cost? ~S |
| All times are GMT -8. The time now is 03:56 PM. |
