no fuel issue
I have a no fuel issue. I jumped the relay and the pump didn't run so i thought pump. changed it just for pressure reasons because the orininal pump still works. what can it be?
matt
1988 944 with early motor
1974 Bronco,
1965 BSA Lightning
Old 02-04-2011, 12:37 AM
Time to get out the meter and check for voltage at the pump and back track, also check the fuse #32 or #33 I believe. If the fuse is bad you won't get power to the DME Relay.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 02-04-2011, 12:43 AM
Thats the thing fuses are good. the only thing i can think of is a bad wire or does the board that the relays plug into go bad?
1974 Bronco,
1965 BSA Lightning
Old 02-04-2011, 12:49 AM
