Bought coilovers, need springs bad! 8"x2.5"
I bought a set of koni's with ground control sleeve off rennlist. i was told i needed an 8' spring, and the sleeves were adjusted about 2" from the top, my roomate let me use a set of 7" springs, so i adjust the sleeve all the way up to compensate for it.
The car is SLAMMED. i'm a sucker for low cars, but my lower control arms are a dcent amount past the 90 degree max.
So i need some 8+' by 2.5" springs ASAP.
Let me know if you have any for sale. thanks.
Old 02-17-2011, 07:03 AM
Toofah King Bad
Rasta Monsta's Avatar
$120 brand new at Paragon, plus choose your own spring rate.
http://www.*****************.com/product_p/hypercoil2.5.htm
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-17-2011, 07:47 AM
Thank you sir!
Old 02-17-2011, 08:44 AM
