Rebuilt engine, no oil pressure
I rebuilt my 89 2.7L NA engine this winter starting with a new block, and as commonly happens, can't get any oil pressure. I read tons of posts on here and Rennlist, and tried most of them without success. So I thought I post what I've done and see if anybody has any insights.
I've done the remove all plugs, dme relay and coil wire, primed the oil filter holes and crank the starter for 30 seconds, oh probably about 50 times now with no success. Tried the fire the motor route, that's worked for me in the past, but this time no pressure after 2-3 seconds so I killed it. I've removed and replaced the power steering pulley to make sure it wasn't cocked, the crank washer is positioned correctly, and the crank bolt is torqued to 155 lbs.
Yesterday I pulled the OPRV and it's not stuck, and moves freely. It's the one piece version. There was oil coming out from the hole when I pulled it, I assume that's a positive sign. The oil pressure sensor is brand new.
Tonight I tried a attaching a clear hose to the oil filter center tube and filling it full of oil. I then cranked the motor CCW by hand to see if I could prime the oil pump, but after a couple minutes of rotation, the oil level in the tube hasn't budged a bit.
Tomorrow I'm thinking of trying the 10lbs of air pressure in the dipstick tube while spinning the starter to see if that works. Worse comes to worse, I'll pull the oil pump and replace it with another but for obvious reasons - too much work - I'll save that for last.
Any other suggestions out there?
- Cris
http://alpinemotorsports.blogspot.com
Old 02-03-2011, 04:45 PM
well...does the engine have plenty of oil in it?
Old 02-03-2011, 04:59 PM
Proprietoristicly Refined
John_AZ's Avatar
Just pure guesses:
Did the oil pump match the new block? Early pump (5R) vs Late pump (9R)?
Last post...
Clark's Garage Message Board :: View topic - Rebuilt engine- no oil pressure
Oil pickup tube cracked?
Car not level?
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-03-2011, 05:18 PM
Yup, plenty of oil
Not an early oil pump, it came from an 89. Car is level, on a lift actually, and the oil pickup tube wasn't cracked.
Thanks for the link, I'll take a look.
- Cris
Old 02-03-2011, 06:13 PM
Redline Racer
HondaDustR's Avatar
Try cranking with the OPRV removed. Seems like that's what did it for wildman who recently had the same problem, only it took both cranking and crankcase pressure to get it to finally prime.
Can't seem to crank up any oil pressure.
Wouldn't the center hole for the oil filter only lead to the bearings? The oil flows from around the outside of the filter element to the center, right? Maybe pour oil into the outer hole at the oil filter mount. It would have to fill the oil cooler before reaching the oil pump. Oil System Flow Diagram
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 02-03-2011, 10:24 PM
good question. where does the oil go when you put it in the center?
Old 02-04-2011, 07:24 AM
Redline Racer
HondaDustR's Avatar
It should go to the main galley through the block that feeds the main bearings and the cylinder head if the oil flow diagram is correct. The dirty side of the oil filter is always the outer side. The oil cooler is before the oil filter but after the OPRV.
Old 02-04-2011, 07:45 AM
so just a myth in priming through the center tube...that's how i primed mine, i guess i just got lucky.
Old 02-04-2011, 08:09 AM
Redline Racer
HondaDustR's Avatar
Personally, I think so. I didn't pour any oil there after my rebuild and it primed just fine with a little persistence. It seems to take awhile because it has to fill the oil cooler, the oil filter, and all the oil galleys before it finally meets the resistance of the bearing clearances in order to develop pressure at the pressure sensor. Pouring oil down the center hole may help a rebuild reach prime faster, since the assembly lube will help keep the oil that's being added, going into the main galleys from just running out the bearings.
Old 02-04-2011, 01:51 PM
Well, removed the OPRV and tried cranking (plugs out) with and without about 15 psi applied to the dipstick tube, and no luck. So I guess the next step is to drop the pan and pull the oil pickup tube, re-check for cracks, and replace the seals, and then retry this stuff.
If that doesn't work, I guess I need to pull the oil pump itself off the block.
thanks for the tips guys.
- Cris
Old 02-05-2011, 03:48 PM
John_AZ's Avatar
When you assembeled the front crank pulleys, are you sure you put them on in the correct order? Could you have reversed one pully----flipped over?
Is the oil pump sleeve getting the tension it needs?
Again just a guess
GL
John
Old 02-05-2011, 04:23 PM
Nobody Special
Everyone has mentioned the usual suspects so I'll go wide. Any chance the new block was assembled with too much assembly lube? There have been more than a few people that have had this problem until the engine warms up and frees up the grease to flow...same goes for the Vaseline in the oil pump trick to prime it. Another possibility is the girdle not being absolutely flush with the block during assembly...it keeps the oil pump from priming if there is a gap that won't seal with the Loctite 574. Probably not your issue but can be another source of priming problems.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 02-05-2011, 06:10 PM
Anything is possible, but it's doubtful. Its not the first motor I've rebuilt, and I have the factory manuals and wasn't hurried at all during the reassembly.
I like your thinking, thanks. I was getting to the end of my tube of assembly tube and didn't want to go get another one, so I don't think I over lubed it. Didn't use any vaseline in the pump, so that's not a problem. And I remember checking the girdle and it was on nice and flush. Nice thoughts though!
- Cris
Old 02-05-2011, 07:19 PM
commdiver's Avatar
I had same problem when doing a rebuild, and after trying all the usuall things still no psi! I took crank pulley off and checked the large crank washer and o-ring seal on oil pump gear, looked ok so I taped the gear and spun it with a hammer and large flat head! Then put it all back together and torqued with starter out and flywheel lock.
So then I bit the bullet knowing I had assembly lube on everything and started and ran it for about 35 seconds at idle and it finally caught pressure. At idle with plenty of oil or assembly lube less than 1 minute is not going to kill the thing? You might want to try filling both sides of oil filter housing, also I know its killing a good new filter but I have heard of guys using a newish filter with a tiny hole drilled in it to relieve air gap while running engine. Once oil psi builds it starts leaking then you obviously have a watcher with rag and kill it then install new filter?
'83 944 ROW zermatt silver/black, sunroof & A/C factory deleted, houndstooth sport seats, 7Q - 220 LSD short fifth, F & R 23.3 MM 951 M030 suspension, 16" fuch's, manual windows, club sport mirrors, Blk/Wht gauges, rear seats & all sound deadening removed, 968 rear wing, fiberglass hood & 937 F bumper
Old 02-05-2011, 07:29 PM
porscha
matty89's Avatar
i suspect that the oil pump has something to do with it or you have a pinch'ed oil cooler hose that is blocked
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 02-06-2011, 05:59 AM
ace_944's Avatar
Did you forget to install the oil pick up tube seal?
Old 02-06-2011, 07:33 AM
After pulling the front apart I think I know what the issue is. Here's the crank with the oil pump. Looking closely you can see the toothed sleeve isn't flush but sticking out about 1/8th inch.
Here's a pump from my used parts collection. The sleeve is flush with the seal.
So it seems that the toothed gear is not cleanly engaging the gears of the oil pump. It's either cock-eyed or jammed. I could have sworn it was all fine when I put it together, but that was 2 months ago.
So any suggestions on how to fix this other than pulling the motor from the car?
- Cris
Old 02-06-2011, 04:35 PM
Redline Racer
HondaDustR's Avatar
I don't think it's supposed to be flush. All the ones I've seen stick out a little bit like in the first picture. You don't want anything to rub the oil seal. If you have one that's flush, it doesn't rub, and everything lines up and works fine, then I guess it's no big deal. Does anyone know if there are two different oil pump drive sleeves to go with the early and late oil pump? Maybe a sleeve mismatch.
Edit: actually after looking at the second picture, that pump appears dismounted from the engine. If so, the sleeve is probably bottoming out on the edge of the drive splines. On an assembled engine, the sleeve stops against the crank journal on the end face and not against the oil pump gear and the ends of the spline slots. The pressure of the crank bolt squeezes the sleeve against the crank and that's how it is driven. It's essentially what the crank bolt is torquing against, and also why it's so important to torque to 158 ft lb.
Old 02-06-2011, 05:53 PM
You're correct, the 2nd pic is of a unmounted pump, that is on my work bench. What you are saying makes sense. So it sounds like what I have is correct then. So no resolution then.
I guess the next step then is to drop the oil pan and verify the integrity of the oil pickup tube and seals. Just to rule them out.
- Cris
Old 02-06-2011, 06:49 PM
You said the OPRV is the one-piece style. Do you know that there is also an early and late style - one is longer than the other... An early one-piece OPRV in a late block will not seal properly and will not make oil pressure.
Old 02-07-2011, 04:57 AM
