Found oil in the throttle body...
nvm, false alarm
Old 02-15-2011, 06:15 PM
ah just found a thread that says it might be the AOS...
Old 02-15-2011, 06:20 PM
Looks like you get to do your first intake removal!
Old 02-15-2011, 06:28 PM
Proprietoristicly Refined
John_AZ's Avatar
The "sweet smell" is coolant.
Check for leaks with a rented/deposit coolant pressure tester from your FLAPS (friendly local auto parts store) like AutoZone or ???
Put in 10-12 pounds of pressure and watch for drips.
IF--IF---IF you do not find drips, get a leak down pressure tester and check>
Compression-leakdown test
I replaced my fan relay switch on the radiator and it cured the "sweet smell"
and yes, I agree with JRboulder----need AOS seals
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-15-2011, 07:21 PM
Don't worry. An intake removal is easy. We should start an intake removal tips and tricks thread.
Jackson
Old 02-15-2011, 07:53 PM
Jackson
yes! i could use some pointers
Old 02-15-2011, 08:50 PM
Clark's Garage Home Page
Old 02-15-2011, 09:06 PM
