Al S's Avatar
944 outer door handle finger pull replacement
Has anybody ever dismantled the outside door handle, and changed only the finger pull lever? Mine broke off
1987 944, non electric locks.
Thanks!
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 02-21-2011, 01:13 PM
yarfk
kfray's Avatar
Only a guess, it would probably be easier to get a used handle.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 02-21-2011, 01:34 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
It's not to hard of a job - Just punch out the center pin that holds the finger lever in place and remove the finger lever piece that's left, and make sure that you retain the finger lever spring as it will have to be re-installed with the new parts...A new spring pin is available at the local hardware store (Also sometimes called a rolled spring pin).
Also handy to have a long nose 3/32" punch because some of the spring pins in place are flared on one end. The long nose punch gets past the flair and hits the solid land just past the flair to make removal easier...
Have Pfun
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-21-2011, 02:21 PM
Al S's Avatar
Thanks Cocacolakidd !!
Al Shkuratoff
Old 02-22-2011, 01:02 PM
