-   -   Engine removal (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/592734-engine-removal.html)
Dan Himan 02-19-2011 06:33 PM
Engine removal
Can I remove my 944S engine with out pulling the dme harness thru the fire wall? I see I can disconnect the connections in the back area of the block when I am lowering the engine. There is the idle stabilizer valve connection under the intake that might pose a problem.
krystar 02-19-2011 09:05 PM
so just disconnect all the connections on engine side of the harness. not that many. two for raidator and ect sender, two for oil pressure, 1 for tps, 1 for afm...think there's another two for emissions stuff, speed/ref sensors....i think that's about it. might be another couple that i missed
trivgar 02-20-2011 06:27 AM
It's much easier to just pull the harness.
bebbetufs 02-20-2011 06:43 AM
If you don't want to remove the intake and possibly the timing belt cover to get to all the cables and cable ties you should pull the harness. I left it in the car, but in hindsight it would have been easier to pull it.
