951 transaxle in a 944
Greetings pelicans,
My ring and pinion finally bit the dust on Saturday. I have a spare 951 open diff transaxle. I was wondering if anyone had put a 951 box in an N/A. I know it would be somewhat slower off the line, but that doesn't matter to me.
Jackson
1984 944 N/A
Old 03-07-2011, 07:58 AM
White and Nerdy
Tervuren's Avatar
I put a 951 LSD transaxel back in my car when my ring gear cracked on my '84. Its just fine. Its nice to have the taller 2nd gear, real nice. It took me a bit to get used too though.
Shadilay.
Old 03-07-2011, 09:00 AM
Thanks for the reply!
I had thought that the ratios were a little close in the NA boxes.
Jackson
Old 03-07-2011, 09:13 AM
rickharrison's Avatar
With the taller gears it will feel "dogged" when accelerating.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 03-07-2011, 09:21 AM
CaveVan
Send a message via AIM to Streetcrawler
There is a guy in Englewood that has a pile of NA transmissions laying around if you want to go that route.
email him @ pseawalt *at* gmail
(FWIW, I was driving the Cayenne Turbo behind you when you broke the trans)
Old 03-07-2011, 09:40 AM
White and Nerdy
Tervuren's Avatar
Voice of experience? Have you compared the difference when you include final drive ratios? My 944 with the 951 box is much better on interstate on ramps. Its not bad at lights either - I mean, a 951 has to get rolling with the same ratios, and it has lower compression pistons and the turbo is not doing much at a low RPM.
I find having 17's(Instead of cookies) make it feel more dogged in acceleration than having a 951 box. Sadly, the owner curbed a cookie right before I bought, so I had to use the wheels off my parts car, but I drove it with the cookies prior.
Shadilay.
Old 03-07-2011, 02:51 PM
smokin_944's Avatar
One of my buddies at Rennlist did the swap (to a turbo transaxle) on a Series 1 car and said that the highway driving was improved along with gas mileage although Rick has a point because of the taller gears in a turbo box. This swap arguably means less shifting in the city I would imagine...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 03-08-2011, 04:14 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
definitely less shifting. voice of experience since I own an NA and a turbo. I get away with driving a gear lower in the turbo.
I was thinking of at least going to a taller 5th in my 944S as the 21mpg is getting to be annoying at $3.75 a gallon.
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 03-08-2011, 06:04 PM
smokin_944's Avatar
A taller gear is definitely a good thing here because the price is $5.27 a gallon presently.
Old 03-09-2011, 05:39 AM
A turbo needs the taller gears to maximize/utilize its power. The NA does not need the taller gears.
Ask a 944 spec racer...they will tell you from experience.
Rick Harrison
1988 944S
MaxHP chipped
Old 03-09-2011, 07:27 AM
ASE Master
alfadoc's Avatar
Important to remember the OP is in Boulder, CO at 5000 ft. 20% less air means 20% less horsepower. Just moved back to the east coast after 11 years in Denver. It makes a BIG difference.
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 03-09-2011, 03:32 PM
smokin_944's Avatar
Good call. I missed that!
Old 03-09-2011, 03:33 PM
Brooklyn758's Avatar
I dont mean to interrupt. But you guys seem to know alot about this tranny swapping . I have a 88 944 where the Damper was converted to a clutch assembly.It is having started problems .the starteri believe is overshooting ringgear . I think my problem is turbo or large flywheel. cause ring gear is close to starter mounting hole. With a N/A man bell housing .
Any advice ? i have another post with pictures called "starter is starting trouble".&" modified Damper needs modified starter?" .
Can the starter be shimmed or a spacer to push it back 1/2 :" maybe. How would that fair?
i would like to convert .Nbut probably to much or expensive . I have extra an extra damper in case we have to change back .i just need flexplate Do ineed to change bell housing also .Its a man. bellhousing
Old 03-09-2011, 06:44 PM
alphadoc is sharp!
Rick Harrison
1988 944S
MaxHP chipped
Old 03-10-2011, 05:28 AM
It can be easily done. Most V8s are running a 951 tranny.
1983 Porsche 944 - LT1 Project
1987 Porsche 951 - Daily Driver
Old 03-10-2011, 07:55 AM
ernie9944's Avatar
Yes ,but most 944,s V8 conversion are making between 350-400 HP.An humble 944 8V NA between 143-163HP depending on the year,wouldn't you say your talking to different cars now.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-10-2011, 08:56 AM
ASE Master
alfadoc's Avatar
alphadoc is sharp!
That's alfadoc, as in one who doctors Alfa Romeos
Old 03-10-2011, 12:04 PM
White and Nerdy
Tervuren's Avatar
The car that I put a 951 box in made the least power out of all the 944's I've driven, however, it wasn't a peaky motor, and the 951 box I think was an improvement to the car as it let me pull more often in the mid range RPM's. At 50MPH its 5 MPH from 2nd to 3rd and you are pushing the redline with the stock box, in a 951 Box, 2nd takes you just over 100KPH(62MPH), which works out better for me.
If your engine is peaky - you'll be alright once you get rolling, but it will take holding the clutch a little longer and putting the right foot down more. i have driven another 944na with a 951 box, and it was a dog of a car with a bad bottom end on the torque curve. Not as fun to get rolling, but ok once rolling.
Shadilay.
Old 03-10-2011, 12:18 PM
haha!
Rick Harrison
1988 944S
MaxHP chipped
Old 03-10-2011, 12:46 PM
Yup, but it can still be completed.
I've always thought the gears the N/A boxes were too close together, maybe its just me though. Although a 944 with a 951 box may not be the top performer, it might make it a little easier to drive, and if you had a 944S (or a 2.7 for that matter) it shouldn't be any problem.
Old 03-11-2011, 12:04 AM
