Under the car
clutch master cylinder reservior
Does anyone know of a fluid reservior that can be fitted directly on top of the clutch master cylinder instead of having it come from the brake reservior? I have a bit of a custom situation on my hands and it would just be best for me to seperate them. Do you guys know if its just a standard size nipple that connects the reservior line? Like maybe the grommet on it is the same as the brake master cylinder grommet.
Do older bugs or 911s or 914s have a seperate reservior? Any ideas are welcome.
Old 02-21-2011, 06:01 AM
Under the car
A feed nipple on the clutch master cylinder that points straight up rather than at such a sideways angle would do the job as well. If anyone knows where to get one of those that would be great.
Old 02-21-2011, 06:20 AM
Under the car
Nobody with info on this? Anyone done any custom brake or clutch work involving master cylinders and reserviors?
Old 02-22-2011, 03:12 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Take the hose off of the Master Cyl. Reservoir, put a cap on the nipple there and then run the hose to any remote tank. The brake fluid from the tank is only a gravity feed so it's not necessary to get fancy or anything
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-22-2011, 04:00 PM
only correcting a 40 year old design flaw
Old 02-22-2011, 04:15 PM
Arizona_928's Avatar
Originally Posted by cocacolakidd View Post
take the hose off of the master cyl. Reservoir, put a cap on the nipple there and then run the hose to any remote tank. The brake fluid from the tank is only a gravity feed so it's not necessary to get fancy or anything
+1
dolor et pavor
Copyright
Old 02-22-2011, 10:18 PM
sasquatch's Avatar
Find a remote reservoir container from a motorcycle. Specifically a sport bike. It will have a mounting tab, exit nipple, and a bladder equipped non spill screw on lid. Probably pick one up on ebay for peanuts.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 02-23-2011, 04:52 PM
