-   -   question for those who have installed keyless entry (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/593977-question-those-who-have-installed-keyless-entry.html)
Crimson Nape Racing 02-26-2011 03:01 PM
I am installing an Audiovox keyless entry in the 89 S2. It has power door locks, so all I need to do is tap into the relay on the bottom of the steering column. My problem is, the instructions (from Bulldog, because the Audiovox instructions are not very good) say the lock wire is brown/white and the unlock is red/blk. There is no red/blk wire, and I don't want to start stripping wires and see which one works. I have the brown/white wire hooked up and the unit works great if all you want to do is lock the car.
Thanks,
Bob
kfray 02-26-2011 04:21 PM
Pin 7 and pin 9 of the central locking controller are used for lock and unlock it looks like BR/WH, BR/RD the schematics are difficult to read.
Crimson Nape Racing 02-26-2011 04:42 PM
Thanks. I'll give it a try.
Crimson Nape Racing 02-26-2011 07:05 PM
Keith, you are right. Brown/white & brown/red. It works like a champ. Definitely worth $22. Thank you very much for the info.
kfray 02-27-2011 03:33 AM
You are welcome, glad I could help.
