Send a message via Skype™ to massive
944 Spare wheel question
I've got Porsche Cup1 alloys on my 944 however the spare in the boot is a full size steel job. I had the rear wheels off the other day and thought I'd check to make sure the spare fitted, which it did. However the nuts maxed out and wouldn't tighten all the up onto the spare as there was plenty of surplus thread left, am I missing a special spacer or something to get his to fit?
Cheers
Dave
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 02-28-2011, 04:37 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
You may have aftermarket lug nuts so they bottom out on the spare rim because it is thinner metal in the area of the lug holes (Usually the spare rim is steel and thinner, some turbos were aluminum and a little thicker in the lug area). To mount the spare "as is" find some open top lug nuts for it...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-28-2011, 07:23 AM
Under the car
I think the early cars came with 7mm spacers and it is possible that it was removed when the cup wheels were fitted on the car. How much extra thread do you think you have? More than a quarter inch?
Old 02-28-2011, 10:00 AM
Cheers fellas, I reckon I've got about 3-5 turns to go on each nut, so yeah I guess quarter inch as you stated. Not sure whether just to dump the spare wheel for one of the smaller space saving ones or just carry a can of tire weld
Old 03-02-2011, 02:33 PM
Tags
spare wheel spacer
