Dino steering wheel into an 86 944?
Can anybody help me out here? I have an 86 944 (so no airbag) and I want to replace the stock leather wheel with a smaller unit with a larger rim for autocross. I already own a Dino wheel (80's flashback) that I would like to use. It has the 6-bolt pattern, but I don't know if it's the same as the Grant or Sparco patterns.
Any advice? Where can I buy adapters? Should I abandon this wheel and buy something that's pre-engineered outright?
Thanks!
Old 03-14-2011, 09:15 AM
fiat22turbo's Avatar
Dino's are similar to the Momo pattern, but are sometimes larger. Measure the bolt pattern spacing.
I have one in my 79 924.
Picked up a Grant 5-bolt adapter for the 924/944 and then bought a Grant to Momo adapter. The Momo adapter was marked, then drilled and tapped to use the larger Dino/Lecarra pattern.
You can find a Momo to Dino/Lecarra pattern adapter as well, use that with a Momo adapter for the 944, which will be more expensive, but it will work without drilling, etc.
Here's an old thread that shows the Momo adapter with the adapter for the Dino pattern....
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 03-14-2011, 12:32 PM
BTW, here's one of the the adapters I was thinking of:
Works Bell Personal/Nardi to MOMO/Sparco Hub Adapter (Black) - P/N: 010038
Stefan
Portland, OR
Old 03-14-2011, 12:38 PM
Hey, thanks Stefan!
(Same Javelin/P71 on GRM )
Michael Pinto
1973 AMC Javelin 360 Project
1986 Porsche 944 PCA AutoX
2006 Mazda5 Daily Driver
Old 03-14-2011, 12:53 PM
Yep, figured that out pretty quickly. Not many folks would sign up with a screen name like that on a Porsche message board (says the guy with Fiat22Turbo as a screen name on multiple Porsche boards, heh)
Stefan
Portland, OR
Old 03-14-2011, 03:01 PM
