Izzy Does It's Avatar
Question Position of Sender for Oil Level
When orienting the sender for oil level into the oil pan, does the pointed "nose" end point upwards away from the bottom of the pan? I know that it can't point downwards because the bolts to the triangular shaped "lid" won't orient to the holes. Though the "lid" bolts will orient if the sender "nose" is on its side, I don't think it belongs that way. Thanks in advance.
1990 Triple Black 944S2
1986 Zermatt Silver Metallic 944
Old 03-17-2011, 11:33 AM
yarfk
kfray's Avatar
The float needs to float up and supply a ground signal out when the oil level is correct.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 03-17-2011, 11:50 AM
Originally Posted by kfray View Post
The float needs to float up and supply a ground signal out when to oil level is correct.
Kfay, so the float up is the pointed "nose" up position, yes?
Old 03-17-2011, 12:02 PM
RedBaron's Avatar
The tip of the sensor is facing upwards towards the engine.
Old 03-17-2011, 06:20 PM
Thanks Red Baron - towards the engine. Will do.
Old 03-17-2011, 08:26 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
point up, float up.....oil level correct float down, oil level down
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 03-17-2011, 09:36 PM
