Izzy Does It's Avatar
Question Interval to Change Rod Bearings
I've done my fair share of reading about the subject and there doesn't seem to be any hard and fast rule about it. At what mileage should rod bearings be changed if the car is not driven hard, abused, raced, and the oil changes are done every 3K miles?
1990 Triple Black 944S2
1986 Zermatt Silver Metallic 944
Old 03-17-2011, 11:06 AM
a long time....if there's no coolant contamination from busted headgasket or oil cooler gasket.
probably on the order of 200k? 300k? miles
Old 03-17-2011, 11:13 AM
If you have good oil pressure and its not knocking, no need to rebuild to just change the bearings.
Old 03-17-2011, 01:08 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
A good friend of mine has 430K on his 86 NA and the motor has never been apart. He has kept it serviced with belts and rollers, water pumps, vacuum lines and various other external parts - but never into the motor...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 03-17-2011, 01:16 PM
