-   -   Looking at another 928S with a strange problem...help if you know (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/59896-looking-another-928s-strange-problem-help-if-you-know.html)
TheStig 02-14-2002 09:59 AM
Hey guys. The loan fell thru for the silver one :( But, i'm kinda glad cuz after checking it out yesterday i found a strange electrical problem with that car so i said forget about it.
A lady called me this morning about her black 83 928S also. She said its a great car and all but one problem....The reverse only works after the car is warmed up and everything. Even though this is a 944 board does anyone know what the solution could be to this 928S? I now have money from a 401K coming in and I'm gonna buy this car if its easy to fix. Could it be a torque converter that causes this? or????? :confused:
Mrmerlin 02-14-2002 10:33 AM
Hi Bro it sounds like a possibly lo fluid condition for the trans , I am guessing that it is an automatic 929s there is a fill check plug on the trans check it on level surface, if it is lo and has been driven like that for a while you be looking at rebuilding it as the clutches might have overheated due to lack of fluid, also to check is the shifter linkage......Stan
Eturbo924 02-14-2002 11:11 AM
Do you have access to the Latest publication of Excellence Magazine? There is an article about a $500 928 in there. This particular car had transmission issues also. It was a simple fix due to a bad trans fluid line. Likely this 928 is also low on fluid as Stan notes.
