mk3tg's Avatar
How do you stiffen stock suspension?
okay this is going to be a really stupid comment but i love the feeling of being low to the ground and i love feeling everybump on the road... My last car had coilovers on it and it just felt great but in my porsche the ride is stiff sometimes but most of the time its just soft when i hit a bump like my jetta any way to stiffen the suspension in the rear and maybe the front i know its possible because people have stiffened the cars suspension, and i want my rear stiff even if that means i'm sacrifing the porsche performance
Audi TT Project 1.8t Stage 3 APR 340WHP
Porsche 944 2.5slow restore
Vortex account
http://forums.vwvortex.com/member.php?434214-Mk3TG
Old 05-08-2012, 07:35 AM
smokin_944's Avatar
Be careful what you wish for because if you ride rough roads, the ride can be jarring. You can purchase 250# springs for the front, 27 or 28 mm torsion bars, and adjustable shocks and voila. This set up will give you one h*** of a stiff ride! Aske me how I know...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 05-08-2012, 07:45 AM
Toofah King Bad
Rasta Monsta's Avatar
As a first step, you could put Bilsteins on it and see how you like it.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-08-2012, 07:49 AM
mk3tg's Avatar
by doing this do i still remain lowered
Vortex account
Old 05-08-2012, 07:56 AM
Toofah King Bad
I have 350 coilovers and 27mm in the rear on my 931. Quite stiff, but spectacular handling, and lower than what is legal for our race car.
Old 05-08-2012, 08:00 AM
mk3tg's Avatar
what brand are they and anything done to the rear
Vortex account
Old 05-08-2012, 08:02 AM
Toofah King Bad
Coilover kit came from pear-a-gone products. 27 mm rear torsion bars came (cheap) from CIP 1. Koni yellows all around, and no more rubber bushes.
Old 05-08-2012, 08:04 AM
flash968's Avatar
if you want your rear stiff, try a stairmaster
seriously though, these cars are GTs and not sportscars. they are not designed to be stiff, and when you stiffen them up, you really lose all civility.
that being said, stiffer springs and torsion bars are how to do it. shocks and such do one job, and one job only, which is to control the spring. they do not stiffen the suspension. they can give you that jarring feeling though if you set them too high for your spring rates, which many people make the mistake of doing because they think the car will handle better. in reality, the car will handle like it's on marbles, but you'll feel everything.
Old 05-08-2012, 08:15 AM
smokin_944's Avatar
I agree with Flash about civility. I would say the ride of my car is harsh unless your on nice highways or roads. But corner!! Holy Crap!! Like its on rails! (My Konis are set to stiff)
Old 05-08-2012, 10:28 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
You can also add rear coil over shocks with 250/300 pound springs - a little bit less hassle that installing rear torsion bars and indexing them.
With all of this there goes your ride and handling quality. By studying your set up and adding quality race components you can stiffen the ride but retain the handling quality for racing or track time.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-08-2012, 11:23 AM
9FF 9FF is offline
9FF's Avatar
Do what Clark says, scroll down to "Sports Suspension" and follow his advise. You will not be disappointed: http://www.clarks-garage.com/pdf-manual/susp-15.pdf
Old 05-08-2012, 11:59 AM
... shocks and such do one job, and one job only, which is to control the spring. they do not stiffen the suspension. they can give you that jarring feeling though if you set them too high for your spring rates, which many people make the mistake of doing because they think the car will handle better. in reality, the car will handle like it's on marbles, but you'll feel everything.
What is the proper way to determine Koni Sport Shock adjustment to maintain the optimum ride? This would be for an 1987 944 S model.
Old 05-08-2012, 03:03 PM
9FF 9FF is offline
9FF's Avatar
Optimum: mount them on a shock dyno and adjust valving to match the spring rate.
What everyone does: try them at various settings until you find a setting you like.
Old 05-08-2012, 04:01 PM
flash968's Avatar
if you have aftermarket double adjustable shocks, you can use this:
KONI shock tuning guide
if you have the factory single adjustable setup, compression is fixed, and you only need to adjust rebound
obviously if you have the factory hydraulic stuff, none of this applies
Old 05-08-2012, 04:59 PM
I have the Koni sports adjustable front and rear recently purchased new. I set them up with the default adjustment, as the instructions recommended.
They seem to ride pretty good. I haven't gotten airborne, hit my head on the roof, or so much as squealed the tires yet.
Old 05-08-2012, 05:39 PM
