Stock bushing instalation
Any tips or tricks to installing stock rubber bushings. I'm in the process of replacing all the front suspention bushings especialy the controll arm bushings. not so fun to take off.
I'm thinking of using silicone spray to help with the instalation
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 04-01-2011, 07:30 PM
meister member
speedracing944's Avatar
Liquid dish soap.
I did the harder poly bushings from Weltmeister with drilled and tapped grease zerks. I am about to tackle the rear suspension starting tomorrow.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-01-2011, 07:38 PM
Originally Posted by speedracing944 View Post
Liquid dish soap.
Speedy
whaaaaaat... No way, that's they way i would put on bicycle grips on my handle bars when i was a kid lol
What kinda soap do you use i got some dawn baby
Jaime O.
Old 04-01-2011, 07:42 PM
RedBaron's Avatar
I used silicon on the rubber bushing install on my front sway-bar and it worked out well.
Old 04-01-2011, 07:49 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Plain old rubbing alcohol, once the bushing is on, it will completely evaporate. Soap will leave a residue that never evaporates, and silicone will take a while to evaporate, and can cause the bushing to slip and slide in the bracket.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 04-01-2011, 08:22 PM
Toofah King Bad
Rasta Monsta's Avatar
Remember not to tighten the front mount until the wheel is supporting the weight of the car.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-01-2011, 09:57 PM
Are you referring to the controll arm bushings and hardware or the the sway bar bushings and hardware?
I have some more reading to do but im asuming
a. install bushings on controll arm
b. install control arm and hand tighten bolts or fully tighten and sit in car for 30 min so that the rear bushing will level out and so rest will settle
c. let the car sit for half of the day before driving to insure all bushings have settled
that's kinda the idea i've read when searching the net on bushing lubricant
Jaime O.
Old 04-01-2011, 10:37 PM
I will have to try that in the morning.
I used heavy duty silicone spray and the sway bar busings that go on the controll arm went in pretty easy but it still able to kinda slide it a little so i may have to re do it, we will see if it's still the same when i check it in the morning.
Jaime O.
Old 04-01-2011, 10:42 PM
Toofah King Bad
Referring to front control arm bushings. Tire should be on a ramp before torquing.
Old 04-02-2011, 08:35 AM
