-   -   How do I permanently disable the brake pad warning system? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/60087-how-do-i-permanently-disable-brake-pad-warning-system.html)
Scott R 02-16-2002 03:54 PM
I just replaced the rear sensors today to ket that Damn waring light off, and it stayed off for a few seconds, then the next bump I hit it went on again!! So how do I disable it? Can I tie all the leads together? Can I dosconnect something? I can't stand that red light for another minute!
IceShark 02-16-2002 05:08 PM
That system is a closed loop and any break in it sets the light off. So you could just cut the wires at each wheel and solder them together.
Knowing that it is a closed loop you also could probably track down where the break is and fix it.
Scott R 02-16-2002 05:22 PM
Thanks!!!! I would rather just loop them then deal with these cheapo sensors anymore!
