-   -   torque specifications sequence (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/602072-torque-specifications-sequence.html)
IDO944S2 04-09-2011 04:42 PM
HI I need help replacing valve cover out 89 s2 , my valve cover is leaking little so plan to replace the seal, but i don't have OEM manual, should be a torque specification for the longer bolts and shorter ones and a sequence? that someone can look in their manuals if have it and help me please!
Mericet 04-09-2011 08:35 PM
Same specifications for both the short and the long bolts: 10Nm or 7.5ftlb. I did not see a specific sequence for tightening these. In cases like these, I always start in the middle and work my way out in a cross pattern.
Grandad#3 04-10-2011 09:27 PM
Like was said above "Always start in the middle and work your way out in a criss cross pattern." Any time you have multiple bolts install finger tight first and then torque to specification. Go to the link below and scroll down to #21. The picture shows the sequence of how to tighten the bolts.
http://www.clarks-garage.com/shop-manual/lube-06.htm
Cheers,
Larry
ernie9944 04-11-2011 12:51 AM
Neil is rigth, torque is no than 7.5 ftlb or they will break (and they are expensive to replace).____Larry the op is talking about the valve cover not the oil pan;)
M44/41 04-11-2011 11:34 AM
Its really a simple case of feel. These bolts are brittle and exspensive. Most dont have a torque wrench that can read such a small rating...I don't. Be cautious, whats the worst that can happen, a minor oil drip on a hot manifold? If so nip it up a lil'. As a 944S2 owner your hood should/will be raised frequently - if not just to admire the engine.If a weep appears then just nip it up a tad. Really no need to worry if you are already alert. Worst thing to do is to over-tighten and snap them off/be a bad PO and leave the drama for the next owner.
ernie9944 04-11-2011 12:03 PM
:eek:
I still say you can torque them to 7.5 ftpd without drama & end up with no oil leaks,And since they are expensive to replace if you snap them, this the reason the OP was advice to be carefull ,what migth be a case of feel for you migth not be for other (AND I DON'T SEE NO DRAMA IN GIVING THE RIGTH INFOS ).
M44/41 04-11-2011 04:04 PM
Originally Posted by ernie9944 (Post 5957316)
:eek:
Your not wrong fella ;)
Grandad#3 04-11-2011 06:36 PM
Hi Earnie, I know the Gent was asking about the valve cover. The example I gave was only to see how to torque the bolts, a visual aid, same as the oil pan bolts.
Oil Pan Gasket Replacement
Cheers,
Larry
ernie9944 04-11-2011 06:42 PM
Cheers,
Larry
Got you Larry my bad I should have scroll down.:)
