SLED GUITARIST
Broke Spring,
Will One valve with both springs broken, inner and Outer, on a 16 valve cause a 0 compression? Outer in 3 clean pieces, inner into 2.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD ![]() |
Custom User Title
Sounds reasonable. Without the spring, the valve would likely hang open.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
yep sure will hope it hasn't dropped low enough to get hit by the piston and bent.
86 951 well modded 94 968 Iris blue daily driver |
Toofah King Bad
Don't think it would bend without the cam holding it open.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
it'd prob hit the piston and just ride up and down unless some part of the spring catches and jams.
not good but not end of the world |
