Replacing front struts, But I have a few questions...
Okay So I managed to get the front struts off with out any power tools and my first time taking off Macphersons, it was hell but its done, I have a set of struts ready to go in but I was wondering do I need to replace the lower strut bolts and washers, one or the other or can I get away with reusing them?
Mark S. Certified Porsche Newb
Alea Iacta Est.
1987 924S 67k miles, all stock besides weltmiester Throttle Cam
87 944 Turbo shes got a few goodies. New DD
Old 04-25-2011, 03:08 PM
You can re-use them unless they are damaged.
Dont forget to put in 50cc/50ml of ATF in the cartridge after you clean it before installing the new struts.
Im pretty sure you year takes the spongy little gasket. I did this for 2% with some High density foam for sealing windows and doors as i didnt want to spent 8$ each for the little buggers.
I also put in fresh Honda moly 60 in the bearings on that top strut assembly as mine were dry and lubed the spacer as well
Dont forget to check you're brake lines
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 04-25-2011, 03:31 PM
