how to wire a horn?
Hi - I recently purchase a 1987 944 Turbo that is track ready. Problem is, I drive to the track and I need to pass NYS Inspection. There is not a working horn. Assuming all the necessary wiring is gone, how would I go about wiring a horn into my car?
Josh
Old 05-25-2011, 07:20 PM
alan6272's Avatar
You can use a remote horn button from your local auto parts store. Just follow the directions its really easy and as long as it's easy to reach from the drivers seat it will pass inspection.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 05-25-2011, 07:28 PM
vdubr928's Avatar
Horn has 2 connections. (Even if you have to buy a cheapie horn from auto zone) one side will be hot all the time. Preferably fused. the other side will go to your button. The other connection on your button will attach to a know ground. Pushing the button provides ground to the other terminal on the horn thus closing the circut. This is called a ground trigger.
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 05-25-2011, 09:26 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
And even a different way to wire it in could be to come off the Ignition Switch to the horn button, + switched terminal at ignition switch back side. Then run the power line from the button down to the horn + side. Then to ground the - side of the horn run a short line to a good metal ground at front.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-26-2011, 02:06 AM
