Angry 944 turbo oil leak! Help!
Hello guys, i am in need of some assistance i have a hugeee problem with my oil filter, it keeps leaking oil, i clean up the mess and re-tighten the filter and when i rev the car the filter seems to alllow oil to leak out, the oil is a lot. also when it leaks the oil looks very filthy, ive changed the oil out twice, and yet continues to look bad very sludgy.
I just did a turbo job, cylinder head job, and also the oil filter mount.
Please help guys and asap!
Old 05-03-2011, 06:13 PM
Custom User Title
mikepellegrini's Avatar
Oil pressure relief valve is stuck and the over-pressure oil is blowing out the seal on the oil filter? That'd be my guess...
Or maybe a defective seal (o-ring) on the filter?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 05-03-2011, 06:39 PM
Banned
are you positive you
A.) removed the old filter gasket before new install
or
B.) replaced the gasket that was included with the new filter?
Old 05-03-2011, 06:40 PM
Did you get the oil filter mount aligned properly when you re-installed it. Like Mike mentioned, high oil pressure will cause that.
Old 05-03-2011, 07:05 PM
Agh I got the alignment tool but I didn't know what to use it for...
I did remove old gasket and the replaced with new. I have tightened this filter so much.
But I'm not sure how to use the alignment tool
Old 05-03-2011, 07:21 PM
Could the oil filter be the incorrect fitting?
Old 05-03-2011, 07:22 PM
