Timing Belt replacement
Next weekend I will be dropping my spare engine into my car. The donor engine has sat for three years and the previous owner had got the belts and rollers changed. I regularly turn the engine over by hand.
Can you guys provide advise on what I should do to the engine before installation.I will be definitely changing the thermostat, engine mounts and cleaning up pipe connections from rust
Would you the change belts? Is there any real need because it's not like they are getting wear.
1983 Porsche 944 2.5Ltr
2004 Holden Monaro 5.7 Litre
1976 Triumph Dolomite Sprint 2L 16V
1999 Daewoo Lanos (everyday car) 1.5L
Old 05-01-2011, 05:14 PM
SLED GUITARIST
Dan Himan's Avatar
Get new belts because of age, inspect the rollers, new ones will not spin freely.
Get taps for the bolts, when the engine sits, the oil and debris harden causing issues with the bolts being removed and reinstalled.
Make sure your pulse senders are gapped correctly before installing engine.
Check crank shaft bearing play. Heck install a crank scraper while the engine is still out.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 05-01-2011, 05:25 PM
"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
man 944 owners dont mess around with there timing belts considering a cheep neon belt last about 10 years - 105,000 miles!
1986 Porsche 944 2.5
2004 Jeep Grand Cherokee Limited 4.7 H.O.
2000 Plymouth Neon
Old 05-01-2011, 08:59 PM
SLED GUITARIST
Dan Himan's Avatar
Once you have one go, you become more pro active. I have changed a cam and balance belt in @ 40 mins. Which includes 5 minutes of inspecting things.
I think its a love thing.
Old 05-01-2011, 09:12 PM
The belts in my car lasted 9.5 years before the WP blew. It now has new belts.
Old 05-02-2011, 02:13 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
mine lasted until it broke. $2000 in parts and machine work later I'll be changing them every 3 years.
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 05-02-2011, 02:17 PM
Redline Racer
HondaDustR's Avatar
Yeah, but you could probably run a neon camshaft off a rubber band. Just follow the safe advice. 3 years or 30K miles. Rubber belts dry rot just like tires and other rubber things when they sit around for years. It's a $15 belt and an hour job for a skilled DIYer. Replace the water pump if the bearing feels rough or loose at all.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-03-2011, 12:38 AM
