968 Instrument panel died
Driving a 1994 968, hit a bump and everything is dead- speedo, tach, all gauges.
Checked & change the fuse, climbed under the dash and found no loose wires or connections.
Ideas?
1991 964 C2 Cabriolet
1994 968 Coupe
1976 911S Track Car- "WayFast"
1972 914
Old 05-22-2011, 06:15 PM
vdubr928's Avatar
My 928 has a vdo box under the drivers foot pad. You have to remove the whole piece that your left foot rests on. This unit controls alot of the error checking. It is a vdo unit. I don't know what you would call it. Ccm or check control module. Not sure where it is on your car or if it can cause this issue bot it interfaces with all the gauges.
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 05-22-2011, 08:14 PM
968 GUY's Avatar
Have had this problem before. The connectors have tabs(levers) that hold the two halves together. They are easily broken by whomever is not aware that they are there. If one of the two levers is broken, a good bump can pop one side out just enough to cause a bad connection.
I am guessing that you pushed on the connectors, I know they are hard to get to from under the dash. I have taken gauge panels out enough on my cars that I can do it quickly and w/o removing steering wheel.
I would first give a firm, "tachnical tap" to gauge panel, and if that didn't work, pull it and look at connectors more closely.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 05-23-2011, 09:22 AM
relay 15 or ralay x
no guages
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 05-23-2011, 09:42 AM
