Toofah King Bad
Rasta Monsta's Avatar
Ground Control Camber Plates
Attractive price:
Ground Control - Camber/Caster Plate, 944/924 (Pair)
But are they any good?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-21-2011, 10:43 AM
smokin_944's Avatar
Rasta, I know a guy that runs them on his LT1 944 and he thinks they are good. I don't know much about them and I am leaning towards the Racer's Edge plates because they don't raise the ride height.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 04-22-2011, 09:39 AM
armandodiaz's Avatar
Used them for 3 race seasons on my 944cup car never had a problem.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 04-22-2011, 10:33 AM
924RACR's Avatar
I believe those are essentially the ones we've been running on the #77 for going on a decade... though ours are supplied by Paragon, it's the same design, perhaps just made under contract.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 04-23-2011, 03:57 AM
Toofah King Bad
Went for these, they are great. Very impressed with design. . .upper spherical bearing does not get ANY axial loading, as the weight of the car is supported by a bearing built into the spring hat that comes with the unit.
It was also a big help getting rid of the factory bits, one of which had a broken bearing!
Old 06-04-2011, 12:57 PM
smokin_944's Avatar
Rasta, did they alter the ride height at all? I considered GC camber plates but didn't know if it would alter the height of the car or not.
Old 06-04-2011, 03:19 PM
Toofah King Bad
Ride height could be a problem, although they do sell both a top mount and a bottom mount plate.
However, their coilover kit with adjustable front ride height is pretty cheap, and as long as you're upsetting the alignment anyway. . .
Old 06-04-2011, 06:15 PM
Custom User Title
mikepellegrini's Avatar
How much caster do they give you? My 83 has almost no caster adjustment.
Spec is 2.3-3.0*, but the best any alignment tech has been able to get is 2.1*.
The car had front end damage years ago and that may have squished everything to the back.
The car drives and handles well, but with negative the caster, it tends to follow bumps and the steering is very reactive, which I dislike.
Would these plates help a problem like that?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 06-04-2011, 09:26 PM
