Routing the O2 sensor cable on the 951?
Is there a special trick to routing the cable from the 02 sensor in the 951? There are exhaust pipes everywhere and I can't remember where the cable was routed originally. I'm worried it will melt if it ends up against one of the pipes.
It will melt if it hits the down pipe. I spliced my universal aftermarket 02 sensor with the original harness so it gave some extra length to route it. I routed mine over the brake master.
I think I have routed it properly, behind the AOS heat shield lower lip and around the back of the AOS.
Yes, underneath the heatshield for the downpipe. It usually goes just in front of the AOS, but going behind it should not affect anything.
Cheers, Keith |
| All times are GMT -8. The time now is 02:19 PM. |
