P944GUY's Avatar
washer fluid tank removal
Does anyone know real quick if you can just unbolt the headlight motor and the washer tank will lift right up or is it going to be a crappy on my back undoing the power steering cooler lines removal job.....installing headlight washers today...
Beer Cigars and a 10mm socket...
Old 06-02-2011, 09:19 AM
Custom User Title
mikepellegrini's Avatar
It comes out from the bottom. You have to remove the sway bar and I don't remember what else.
I believe Clark's has a procedure for it.
Old 06-02-2011, 09:43 AM
Un-hooking the power steering cooler line mounting brackets and a couple of the inner fender bolts and you should be able to shoehorn it out or in.
Old 06-02-2011, 02:19 PM
gmorken's Avatar
+1
Loosening the brackets for cooler line was enough to allow it to slide out from the bottom on an 85/2 NA. Angle the reservior to ease it out/in.
1985/2 944 Alpine White, Fuchs
Musik Stadt chapter of PCA
Old 06-02-2011, 04:12 PM
Andrew Gawers' Dad
CHICKS's Avatar
Mine just slid out, I gave it some pressure from the top, it didnt hurt anything. 86 n/a.
Old 06-02-2011, 08:07 PM
P944GUY's Avatar
thanks ..got it..got the headlight washer pump installed and doing the drilling in the bumper tomorrow for the jets...and the hoses...
Old 06-02-2011, 10:05 PM
