"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
Porsche Crest Bad suspension help!!
found out I have up and down play because my strut inserts are blown.
Side to side play from drivers side ball joint.
My question would be how hard would strut inserts be to install? and how hard is the ball joint is it pressed in or do i need to buy a new controll arm which I dont wanna do (500 bucks)
1986 Porsche 944 2.5
2004 Jeep Grand Cherokee Limited 4.7 H.O.
2000 Plymouth Neon
Old 06-08-2011, 08:02 PM
What year vehicle? You can rebuild both steelnand aluminum control arms. Struts are the same as any other car with them, spring compressor, impact gun yada yada. On those that have a sealed cartridge you need to
Cut and drill The original case to add inserts not sure what year you have to do that but it is possible to do either way
Old 06-08-2011, 11:39 PM
mayPOR944's Avatar
its an 86, i would be nervous rebuilding the control arm because its aluminum
2000 Plymouth Neon
Old 06-09-2011, 11:32 AM
Toofah King Bad
Rasta Monsta's Avatar
Paragon has a service where they install Koni inserts into non-rebuildable struts.
I have't done the aluminum arm refresh, but I hear it is a pretty straighforward job. Check out the directions here:
Rennbay - Porsche 944 ball joints, power steering, brakes, odometer gears & accessories
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-09-2011, 12:36 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
i just got done doing a set of aluminum arms for the 951S. straightforward to be sure! those circlips can and will test your patience, though.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 06-09-2011, 08:05 PM
