Did I kill my motor?
Took my 951 to a track day at Watkins Glen a few weeks ago. Last session it starts missing so I pull it and shut it down. Clutch is on the floor but that's not the issue. It's making a horrible racket and #2 is not firing. A fresh plug didn't help and I confirmed that the plug is firing (timing light fires from all wires). The racket sounds like it's top end, but I pulled the cam tower today finally and apart from a couple soft lifters everything looks good, valve springs are in good shape and no obvious sign of bent valves. What's my next diagnosis step? Put it back together and run a compression test? Pull the head, since I'm more than halfway there?
Old 06-14-2011, 07:47 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
compression?
You could put an air hose to the spark plug opening and listen for hissing out the intake, exhaust, or breather.
The crank might try to spin, so keep a lock on it.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 06-14-2011, 08:42 PM
Capt Squid's Avatar
While the cam tower is off, take a look at the valve spring retainers and valve stems. If one of the valves is slightly lower than the others, you have a bent valve. Depending on how bad it is bent, you could have a slight miss to total crap out.
An extra cam tower nut was left in when one of my engines was installed. When it caught between the cam and lifter, it bent the valve and blew a hole in the cam tower. The engine barely ran.
Jim Richmond
944 Spec race car, SoCal NASA & POC
01 Boxster S
Old 06-14-2011, 09:07 PM
That Guy
Techno Duck's Avatar
I would bet a burnt exhaust valve. Can test with either a compression or leak down test. If doing a compression it will show little to now compression on that cylinder, leak down will have all the air coming out the exhaust. No need to put the cam tower back on for either test.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-14-2011, 10:01 PM
