944ornication's Avatar
Question Clutch Issues
Hello,
I have a clutch problem !!!!!!!!!!!! My pedal depresses completely and wont return.........The fluid levels are fine, and I just replaced my slave cylinder thinking that was the culprit.......well alas, the clutch slave cyclinder wont bleed......is it my master slave cylinder? Could it be gook in the lines? (its been sitting for a while - 4 months) I cant figure this one out.....any help is appreciated oh yeah and my brakes work fine if that means anything.
Clay
Clay Wagner
Old 03-01-2002, 01:29 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
Porsche Crest
Your master cylinder is gone... lot's of post on that... here's one .. http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=15129&perpage=20&pagenumber=1
Old 03-01-2002, 02:28 PM
Clay, before you put a clutch master cylinder, try to bleed the slave cylinder one more time. I had trouble with two different 944s. Then I read a previous post that suggested using a oil squirt can filled with brake fluid. Get some clear hose from the hardware store that will fit tightly on the bleed nipple, and pump the fluid into the slave cylinder from the bottom. It worked for me the first try. Good luck
Ralph
Old 03-01-2002, 03:38 PM
Thanks gentlemen, I will give this a go
Clay Wagner
Old 03-01-2002, 08:25 PM
To check if your clutch master cylinder is leaking, stick your head way under the driver's console and look at where the cylinder's push rod comes through the firewall and connects to your pedal. Pull the rubber bellows on the rod back and push down on the clutch pedal with your hand. If it's bad, you'll probably see fluid coming out from there (this is were I found the leak on mine).
Replacing the master isn't too difficult, except that you don't have much room to work with. Before you begin to bleed the system, remember to adjust the play in your clutch pedal (there should be some tension from the spring pulling on the pedal). Bleeding the system only took me about 10-15min with my wife as my assistant. Be sure that the fluid level does not drop below the feed line for the clutch master.
Joe
'83 944
'70 914
Old 03-02-2002, 03:49 PM
