Rebuild early control arms
I'm looking to rebuild my early steel control arms, I got the ball joints down pretty good, but how do you R&R the other two seals?
Old 01-07-2010, 07:51 PM
dkbautosports.com
962porsche's Avatar
do you meen the bushing ? they press out new ones press in .
Old 01-08-2010, 03:26 AM
Toofah King Bad
Rasta Monsta's Avatar
Couple of suggestions. . .have the arms debushed by a machinist (the fronts aren't that bad, but the rears are awful to remove). Then have the arms stitch-welded along the seams, and powdercoated. Finally, grab some ProThane poly bushings for Rabbit/Golf Mark I (about $25 for both sides).
Results:
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-08-2010, 07:20 AM
Toofah King Bad
Here's another. . .BE ADVISED THE REAR BUSH IS BACKWARDS IN THIS PIC (d'oh)!
Old 01-08-2010, 07:22 AM
I'm actually wanting to know how to remove the rear bushing. I've heard of some people setting them on fire, but that is not what i want to do.
Old 01-08-2010, 02:37 PM
Toofah King Bad
Fire won't help you get the metal sleeve off. It is pressed on (as stated twice already). Easiest path is with the help of a machinist.
Old 01-08-2010, 05:32 PM
Nice Arms
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 01-08-2010, 11:27 PM
gpotts200's Avatar
What is the approx cost for the machinist? Thanks!
1984 Guards Red Porsche 944 NA
2005 Suzuki Forenza
2005 Suzuki SV650 **SOLD**
2008 Toyota Siena
Old 01-09-2010, 04:30 PM
forget the machinest it will vary or they will charge you by the hour. More importantly is what bushings did you get exactly. only other bushing i have seen like that were from another site and they cost an arm and a leg.
Jaime O.
Old 01-09-2010, 06:01 PM
Toofah King Bad
* tap tap tap *
Is this thing on?
Old 01-09-2010, 06:07 PM
Can you clear up what the Stitch-weld is?
Parker Furer
1984 944 alpine white
Old 01-09-2010, 07:04 PM
stitch weld
A good welder will "stitch" up the places that the factory skipped to save costs. Using a pattern that will minimize distortion and result in a stronger than original arm.
Old 01-09-2010, 08:55 PM
gpotts200's Avatar
Where did you buy your polythane bushings?
2005 Suzuki Forenza
2008 Toyota Siena
Old 01-10-2010, 08:57 AM
smokin_944's Avatar
The front end parts are cheap, buy new. C arms, ball joints and bushings are mebbe $150 for the early cars. Stitch welding and powdercoating $100. Done. The only thing I would do different is get performance bushings, ($257) but that is me...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 01-10-2010, 09:26 AM
Toofah King Bad
Originally Posted by Rasta, shouting into the darkness
Prothane makes good polyurethane bushings that cost $25 for both sides. The model to look for is "Rabbit/Golf Mark I" (early steel 924 arms came from the Rabbit parts bin).
Old 01-10-2010, 10:01 AM
smokin_944's Avatar
lol...
Old 01-10-2010, 02:51 PM
Arizona_928's Avatar
where do you get the ProThane bushings?
dolor et pavor
Copyright
Old 01-10-2010, 06:08 PM
Will program for food
ghnat's Avatar
I just googled ProThane bushings...
Maybe this is the site?
Polyurethane Bushings and Polyurethane Automotive Performance Products | Prothane
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 01-10-2010, 06:50 PM
is PCA requiring the arms to be just stitch welded or completely blocked for track use?
Old 01-10-2010, 07:02 PM
Toofah King Bad
Your Prothane part number is 22-201. Bought mine at my local air-cooled speed shop, Halsey Imports in Portland.
Old 01-10-2010, 10:37 PM
