How to bypass speed/reference sensors?
anyone know how to bypass these sensors toallow my car to run ? its my only driver and im broke
Old 07-01-2011, 12:39 PM
In the Fires of Hell.....
kdjones2000's Avatar
Get your sneakers out
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-01-2011, 12:44 PM
lol bypass.
the sensors are only way engine knows when to fire the spark plugs. u should fix em
Old 07-01-2011, 12:55 PM
ok thanks for the info guys, also can anyone explain how to make a jumper for the DME fuel pump relay
so i can test for sparky?
Old 07-01-2011, 01:06 PM
unplug all fuel injector clips, take out one of the spark plug, attach spark plug to plug wire, lay spark plug on intake manifold. crank the car. look for spark
Old 07-01-2011, 01:14 PM
no spark when i did that just now also no jump on tack when i turn it over, my reference sensor plug that resides at the top of the engine is broken, is there anyway that it being broken but still connected that it wouldnt let the signal from sensors go threw? also is there anyway to wire those wires together without the plug?
Old 07-01-2011, 01:38 PM
well IF the sensor is still good, u could get handy with the soldering iron and replace the connector. but do u know the sensor is still good?
Old 07-01-2011, 01:41 PM
no i dont know for sure and do not have the tools or means to test it...
Old 07-01-2011, 02:04 PM
