944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Talking oil sleeve O ring (crankshaft) lubed?
I'm curious if the green O ring that goes in with the oil pump sleeve on the crankshaft has to be lubed with oil. I pulled out the old one and it came out in hardened pieces. I don't want to lube it if it's supposed to be dry.
Also, I was forced to use a 5' piece of steel pipe to extend my breaker bar to break loose the crank damper bolt. What a B--ch!!
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-18-2011, 12:00 PM
Arizona_928's Avatar
yes! all o rings should be lightly lubed!
dolor et pavor
Copyright
Old 09-19-2011, 08:48 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
If you fear lubing rubber or poly parts with petroleum based lubricants try Corn Oil or Veggie Oil - seals will last longer this way. Various manufacturers suggest the use of food grade grease to lube their poly parts - Food grade grease available through Restaurant Suppliers and food industry suppliers. Food grade grease viscosity same as petroleum grease.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 09-20-2011, 10:18 AM
AKCJ's Avatar
I use silglide (spelling?) on most rubber parts.
I guess it's a silcone based paste/lube. Works for me.
Red 83 944
Old 09-20-2011, 02:23 PM
Just and FYI you can get Pure silicone grease food grade in the plumbing section at lowes its made by GUNK. And even at a scuba shop. Even the diving section and Sport chalet might have it.
I just used some Valvoline VR1 20w50 on it on a cool day to keep the that heavy weight oil stuck on there like honey
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 09-20-2011, 02:50 PM
