Sirius Driver's Avatar
Do all 944's have seat belt anchor points on the tunnel?
My 87 came with power seats and had the receptacle end of the seat belt attached to the rail. The manual seats I added dont have the seat belt receptacle attached nor can I see how I could use the old factory seat mount. Before I start tearing my carpet apart, are there stock holes on the tunnel for a 1987 car? Thanks! If not, what can I do?
1982 RoW 3.0 911
1999 996
Old 06-27-2011, 01:40 AM
i don't believe the later cars had the hole. however i think the reinforcement is still there. u just gotta drill the tunnel
Old 06-27-2011, 07:23 AM
Okay, that sounds doable, but also not sure about threading the hole correctly. Does anyone have a solution they've come up with for this dilemma?
1982 RoW 3.0 911
1999 996
Old 06-27-2011, 10:39 AM
put a reinforcement plate on the other side and use a nut and washer
Old 06-27-2011, 02:07 PM
In the Fires of Hell.....
kdjones2000's Avatar
Don't expect to have a nut on your car that you can just bolt up to. You will need to drill and likely reinforce the area. Since this is also where there is heat shielding for the exhaust/TT, it can be a bit of a PITA to do.
Not impossible or anything, but expect it to take longer than you think.
The 1978 924 we have for Chumpcar racing already had that mounting point, but my 1988 951 does not. Not sure if the change happened between '79-80 in the 924's, between the 924/944 change, or at the 85.1/85.5 transition. Maybe someone else knows.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-27-2011, 02:19 PM
vdubr928's Avatar
Later seats had the belt as a part of the seat eliminating the need for the hole and allowing the belt receiver to go back and forth with the seat. Whenever they made the seat change......
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 06-27-2011, 04:17 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
My 83 has the hole in the tunnel. I stopped using that hole and just placed the bolt in it when I installed my later model seats( which are a vast improvement!!)I am assuming the change was 85/1- 85/2.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-27-2011, 06:53 PM
