Loose wheel movement
Was not sure what to call this post.. But here was what I am having happen.
When driving the steering is loose and by that I mean sloppy. Not tight at all. Was thinking maybe the Tie rod, because I did put new tie rod ends, control arms, bushings and all.
Not sure what else other than the rack, but no leaks really did not feel this until I replaced all the above parts. This driving me nuts.
Old 06-27-2011, 06:55 AM
how are the wheel bearings?
Old 06-27-2011, 07:17 AM
M. Murphy's Avatar
I was thinking the same thing. Wheel bearings. My 83 NA exhibits the same sort of behavior at about 55-65 mph the steering wheel has a low frequency shake. Above 65 it goes away. As soon as the rain lets up I'm going to try ajusting the front bearings.
Mike
Old 06-27-2011, 07:35 AM
re
Not a shake just loose. right left movement in the steering wheel. But I will check those bearing out anyway. You never know.
Old 06-27-2011, 07:57 AM
RedBaron's Avatar
It could be tie rods or the intermediate shaft that connects the steering wheel to the rack could be worn.
Old 06-27-2011, 11:20 AM
AKCJ's Avatar
The steering on my 83 with manual rack also seems loose. I took the rack out and had it gone through by a local shop. He said it seemed pretty good. I've also changed inner and outer rod ends. And I did the wheel bearings. It's better but still not as good as I would like.
I suspect there is some wear in the U-joint @ the intermediate shaft as mentioned by RedBaron. Someone needs to come up with a fix for this.
Red 83 944
Old 06-27-2011, 02:49 PM
