CKniht90's Avatar
Send a message via MSN to CKniht90 Send a message via Yahoo to CKniht90
Battery Draining
Since my clutch went out my car has been sitting until I have the $ to fix it. I let it set for about 4 days then I decided to go out and start it. When put the key in and turned it over nothing happened at all!! So I figure I have something draining the power while the car isn't in use. This is the first time I've noticed this since I've owned this car. What are the steps/tools needed to find out what is using the power while I'm not using it? Good thing I have a warranty on the battery if it has gone bad
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD
Old 06-27-2011, 12:10 PM
944sracer's Avatar
Measure the amperage draw between the negative battery cable and the negative battery terminal. I can't remember what the correct draw should be but it should NOT be more then a few milliamps. If it is - pull fuses, pull 1, measure the change (if any), if there is a change then that is your culprit, if not then re-install the fuse and move to the next one.
89' 951 Turbo S Race Car - SP-3, PT-B
87' 944 Diamond Blue Metallic - DD
"Practice does not make perfect. Perfect practice makes perfect" - Ross Bentley
Old 06-27-2011, 10:47 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Check the climate control fan, it's located under the dash behind the small round vent next to the lighter. If this fails, default is ON.
Take a piece of paper about the size of the vent, with the battery charged, turn the key ON, place the paper over the vent, it should stay in place over the vent. Then turn the key OFF, the paper should fall away from the vent, if it stays in place the fan is still working and draining your battery. This happened on my 89NA, and it drove me nuts searching for the default until a friend (Porsche dealer senior technician) told me about this simple test.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-28-2011, 05:12 AM
CKniht90's Avatar
Wow, thanks a lot guys! I'll be able to do this hopefully this weekend! P-Forums never fails me Keep you updated!
Old 06-28-2011, 06:47 PM
Arizona_928's Avatar
The fan itself fails, or the resistor pack?
dolor et pavor
Copyright
Old 06-28-2011, 08:52 PM
89-944NA's Avatar
the actual fan (Bosch p/n 0 130 002 808). Why Porsche designed systems (heater, climate control fan, etc) to fail into the ON position I'll never know. But like I said, I was about to go nuts, trying to find the problem until I was given the tip about the fan motor and a hunk of paper.
Semper Fi
Old 06-28-2011, 11:47 PM
Banned
I believe it is because without at least some airflow you will get exhaust gasses in the cabin when sitting in traffic.
Old 06-29-2011, 06:50 AM
89-944NA's Avatar
The only problem with that theory is that the heater valve default turns on heat not and circulating fan (maybe it's to let you know the valve is bad), and the climate control fan draws air, not expels it.
Semper Fi
Old 06-29-2011, 07:09 AM
Banned
Heater valve defaults to heat so you don't freeze to death if it breaks in the winter.
Old 06-29-2011, 09:10 AM
89-944NA's Avatar
But you roast in the summer LOL This debate could go on forever, I'll ask a member of a local PCA region who used to work for Porsche, AG., now I'm curious
Semper Fi
Old 06-29-2011, 09:39 AM
