-   -   What is this device that is under the glovebox and to the left? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/616595-what-device-under-glovebox-left.html)
Toran 06-29-2011 05:09 AM
Hello All,
Can someone help by identifying this device that is under the glovebox and to the left?
http://forums.pelicanparts.com/uploa...1309349332.jpg
http://forums.pelicanparts.com/uploa...1309349357.jpg
89-944NA 06-29-2011 06:21 AM
That's the fan motor for your climate control, there is supposed to be a rubber flex hose that connects it to the back of the round vent located on the dashboard between the lighter and the glovebox.
This draws air from the cabin across the sensor located in the center of the opening (you can see it in your bottom picture), and adjusts the heating/cooling according to the knob setting.
You are missing hose p/n 944.572.529.00
Toran 06-29-2011 07:22 AM
Thanks you 89-944NA!
What performance have I been missing with the hose gone?
89-944NA 06-29-2011 07:35 AM
Not sure, but without the hose it may degrade the ability to regulate the temperature properly by a small amount....That's just a guess though, figure the hose is there for a reason. LOL
Toran 06-29-2011 07:53 AM
Looks like Pelicanparts has this item as NLA
Toran 06-29-2011 08:01 AM
Does this 944.572.529.00 part have anything to do with a connection to the glove box?
89-944NA 06-29-2011 08:08 AM
No, that would be hose p/n 944.573.613.00. It comes off the right side of the heater core housing and goes across to the vent on the left side of the glovebox. Pelican still has this hose as a special order for $3.00
89-944NA 06-29-2011 08:14 AM
Try dC Automotive - Your used/recycled Porsche Parts resource, they show this hose as "In Stock" @$20.00
and they also show the other hose as "In Stock" @$2.75...may as well order them both from DC and save paying shipping twice.
It's located in the "Body" section, at the bottom: Ventilation: AC Compressors....etc located in the top left diagram, item number 37 (top center) and the other hose (glovebox) is located in the 3rd diagram (center left) item number 13 (upper right, between the large tube and the dotted line)
Toran 06-29-2011 08:17 AM
89-944NA your spot on!
I THANK YOU and the 944 THANKS YOU!
