Porsche Lover
944 (1985/1) engine sputter under load
so my 944 started sputtering a little after work last night, and is progressively getting worse. sitting in neutral, the car revs and idles like normal. but when driving, or under any load it starts cutting out and sputtering. i push in the clutch and it idles fine. To add to it, last week i got a $352 ticket for 60mph in a 25 so i literally have like no money to shotgun it.
any suggestions? |
Banned
more than double the speed limit? around here, they will take your license on the spot and your car -will- be impounded. check your airflow meter as per the guide on clarks garage. |
Has it been happening all on the same tank of gas(did it start after a fill up?). ethanol picks up water. you could have gotten a bad batch. It is a very common occurrence with the new gas. I would make sure the gas is okay then start diagnosing from there
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Porsche Lover
TRUST ME, i do not speed like that anymore. My friend was in a 325e and thought he could beat me to his house, but no, i won. haha
and it started before i filled up, but became wayyyy worst like right after i filled up. so maybe the gas.i'll investigate |
Banned
worse after you filled it up, but started before you filled it. i'm betting fuel filter.
Porsche Lover
thanks. i'll order one and see what happens.
Porsche Lover
so this one might shock you. changed the rotor and cap and that fixed it! haha
doesn't surprise me in the least! my dad was having poor idle on his 40k mile time capsule... turns out that a 944 doesn't run well with a dirty/corroded cap & rotor.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
Porsche Lover
yea, mine was so dirty and i found out that one of my set screws was missing
