Are these for additional grounds?
Hello All,
Are these bolt holes for additional grounds? T.I.A. http://forums.pelicanparts.com/uploa...1309409576.jpg |
A bracket for the brake pad wear sensor / ABS connector mounts there. The wear sensor is grounded to that spot.
Thanks Techno Duck!
In most cases the Cruse Control module bolts there - Are not the ABS controls mounted under the passengers fender liner and also covered in the passengers foot well for the two control modules ? Did '86 944's have ABS ? I'm thinking that with the '87 and up it was an option ?
Thanks Cocacolakidd!
And the WINNER is BOTH Techno and Cocacola...the ABS Sensor/Brake pad wear sensor connector mount there as does the CC unithttp://forums.pelicanparts.com/uploa...1309454603.jpg
Very Nice!
You guys Rock! |
Polar Bear wings and a Brew - fun on the beach.
| All times are GMT -8. The time now is 09:14 PM. |
