Voltage Regulator Install Orientation
Hello All,
Got another question while the car is being worked on. There is enough room to replace the voltage regulator without removing the alternator. Got the old one out, and already forgot if the two prongs should be pointing upward or downward? T.I.A.http://forums.pelicanparts.com/uploa...1309454350.jpg |
Drumroll...and the answer is to install the regulator so the brushes point toward the center of the alternator.
| All times are GMT -8. The time now is 12:25 PM. |
