square dash switch wiring (mirrors and rear wiper)
Hi pelicans,
I replaced my dash at the weekend (what a PITA of a job that is). Took out the one that had been fitted with a terrible dash cover (that I removed, leaving a load of bathroom sealant on the dash - made it look like a bird got in and got scared). Put in the one from my parts car which is cracked, but not too badly (and which I made a very amateur attempt to flock the top of the gauge part). I made a rookie error and didn't photograph or make a note of which wires connect where on the switch that selects left or right mirror, and the rear wiper. Have tried a couple of combinations, that blow fuses when I put the key in the ignition or move the mirror control. Can anyone give me a quick read-out of which colour wire connects where on these 2 switches please - thought it'd be easier than this to connect them back up but testing with a multi-meter gives readings that make it tricky to work out how to connect them up. Thanks Mike
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do. 1986 924S, White, donor car, part way through disassembly. |
