alan6272's Avatar
shifter bushings
So I have read here that the shifter bushings are N/A and can not find shifter bushings for the shifting shaft at the trani. any where "sloppy shifter". Some one had said that a member on here has found a replacement. Can some one lead me the rite way on this?? I plan to fix mine but if I have an idea what to use it would save me alot of time, Again thank you all
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 07-08-2011, 07:41 PM
Are you sure it's not this? This is exactly what mine is doing. Our host sells the lever for $53 and the white bushing for $3.
944 Foot To The Floor: How to remove and replace a worn gear shifter stick on a Porsche 944
Old 07-08-2011, 07:47 PM
alan6272's Avatar
yes im sure thanx, I have seen the slop on top of the transmission. where the shifter rod connects.
catalina22 sold
baja ski boat sold
my toys
Old 07-08-2011, 08:12 PM
Send a message via Skype™ to massive
You might want to think about replacing the whole shifter mechanism with a short shift kit, check out my other post here on how to fit that
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 07-13-2011, 02:23 AM
Tags
short shift kit , sloppy shifter
