flywheel?
I just bought a new Sachs clutch and I heard that its good to replace the flywheel bolts after its re surfaced. Is this true, and is there anything else I should do before I put it all together?
Old 07-25-2011, 03:31 PM
The bolts that attach the flywheel to the crankshaft are "one use only".
Good luck, George Beuselinck
Old 07-25-2011, 04:33 PM
The 12 points? Why is that?
Old 07-25-2011, 04:53 PM
flash968's Avatar
because they stretch
you should also change the ones that hold the pressure plate to the flywheel, due to wear on the tool receiver portion - failure to do that can easily result in a very difficult time removing them later
Old 07-25-2011, 05:24 PM
Proprietoristicly Refined
John_AZ's Avatar
Replace the RMS-rear main seal. The best/easiest seal to use--Elring.
If you have experience by the Pelican Kaco
The Crank shaft has to be oiled with conventional oil or the seal will burn out
Oil the inner seal lips as well.
Clean the cavity and remove burrs on the "screwdriver" indent or the seal will rip.
Press the RMS seal in the engine with a professional or home made press.
If you do not follow this procedure, your RMS will leak and you redo the whole cluch job to replace it.
Set the gap on the reference sensors without the bell housing attached.
The Pressure plate bolts can be reused---but why not change them as well...
For a perfect combination of Pressure Plate to Flywheel, a machine shop should balance the combination after the FW is surfaced.
Check the clutch fork for stress cracks. Check the clutch fork rod for "deep" bearing grooves. If serious, replace.
Get a new TO guide tube, the original may have cracks.
Replace the pilot bearing.
More? sure....
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-25-2011, 05:40 PM
