While im in there....
Planning to do a Front reseal on the 944, is this easier done in car or out of car? Or is it even possible to do it out of the car?
Also while im there anything else that should be done? Or should be checked? HOPEFULLY i can knock this out in a 3 day weekend. But i think im being optimistic... If possible i would like to leave the engine in the car, but if i need i will pull it. Please enlighten me!!!! Thank in Advance guys! |
yea u can def do it while engine in car. i wouldn't pull an engine just for front seals.
u'll need a flywheel lock to get the crank bolt off. |
I am going to replace the timing belt since im there (just done less than 5k miles ago) but if oil has leaked onto it, then it should be replaced. Correct?
| All times are GMT -8. The time now is 03:37 AM. |
