petrolhead611's Avatar
Send a message via AIM to petrolhead611
fuel tank removal
Looks like I have no choice but to try and remove this as 6 attempts using 3 well known brands of repair putty have all failed the moment a gallon of gas was poured into the tank-wondering if the ethanol in modern fuel just instantly attacks the putty. If anyone knows of a brand that really works with modern petrol, please advise .
Anyway I have concerns as follows:
Is the tiny space between rear of gearbox and spare wheel bay sufficient for moving transmission back to disengage it from the torque tube, or does the engine have to be moved forward off of its mountings? How does one remove the exhaust heat shield nuts that have seen 25 English winters;cannot use heat as have a leaking fuel tank. Do I hacksaw it off leaving enough metal on each mountinmg stud to weld it back together? How to separate the exhaust back box form the rest as it has also seen 25 winters but is still in good order-I don't want to buy some after-market silencer that makes a stupid noise..Do people just saw through the pipe then sleeve it on re-assembly?.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 04-26-2011, 03:09 AM
Banned
no? you remove and drop the pipe as a whole assembly. unbolts from the exhaust manifold upfront, drop the hangers in the middle, and disconnect the rubber mounts that hold the muffler.
Old 04-26-2011, 03:24 AM
Proprietoristicly Refined
John_AZ's Avatar
+1 on the exhaust. 2 new exhaust flange gaskets should be ordered.
Yes there is room to drop the transaxle with out hitting the spare wheel well.
The use of a floor jack and a transmission accessory addition on the floor jack will take the weight of the transaxle off your shoulders !! (laugh, laugh)
You have to remove/unbolt the rear linkage. The long shift shaft is bolted to the linkage with a wired security bolt. Put the bolt in a bag and label it. Do not over torque the bolt on assembly.
Repack the 4 CV joints.
There is a foot long black tube that is inside the transaxle. This tube may cause you problems when you reinstall the transaxle. Be patient. Put it back in.
Here is a link with a few pictures. You will only use the beginning portion:
My clutch job, in pictures:
Take pictures of the rear hatch area fuel intake after you take off the metal & carpet covers.
The picture will help you put the hoses back in the correct place.
Get Permatex black rubber sealer for the metal cover.
Replace all hoses on top of the tank--gas and vacuum.
If the tank is welded, make sure the hoses still fit in the grooves and that the welder did not put a brace in the area that prohibits the hoses from laying flat.
The job is real easy the 3rd or 4th time you do it.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-26-2011, 04:49 AM
Toofah King Bad
Rasta Monsta's Avatar
First, you should always listen to John. Second, if that stupid black tube doesn't go in immediately and easily, throw it over the fence into the neighbor's yard!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-26-2011, 08:21 AM
Custom User Title
mikepellegrini's Avatar
+1 on tossing the black tube protecting the shift linkage. I really truly can't see a reason for it being there, except to make it tough to get the transaxle back in.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 04-26-2011, 09:33 AM
Under the car
It keeps dirt from getting into the bellhousing and potentially destroying the input shaft seal faster. Other than that I haven't come up with any other ideas.
Old 04-26-2011, 09:56 AM
Toofah King Bad
Speeds assembly at the factory?
Old 04-26-2011, 10:02 AM
John_AZ's Avatar
I have a solution.
Remove one of the tabs on the tube, opposite the one I have circled...
slide it towards the driver,
lift the transaxle in position,
slide the tube back,
Put a dab of silicone sealer or black rubber around the tube on the outer transaxle bell housing side. Done.
The other purpose of the tube is that when the car dies and sits in a field. the rats and mice cannot make a home in the bell housing.
They head for the air filter box! (Mike )
John.
Old 04-26-2011, 10:34 AM
Custom User Title
John.
Yes they do!
16 Ford Expedition
Old 04-27-2011, 02:46 PM
Thanks for the advice so far;am now investigating ramps or lifts to get the car high enough to comfortably work under in a low garage. I have enough headroom to lift the car a miximum of 32".
Old 04-29-2011, 05:06 AM
Send a message via Skype™ to massive
Here's the complete procedure to remove the fuel tank 944 Foot To The Floor: How to remove and replace a Porsche 944 fuel tank (Square Dash Model)
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 04-29-2011, 08:37 AM
And here's the transmission removal procedure too 944 Foot To The Floor: How to remove a Porsche 944 transmission (Square Dash Model)
Old 04-29-2011, 08:38 AM
I'm dismantling a 924S parts car at the moment. Hopefully lifting the body off the running gear in the next 2 or 3 weeks. The tank seems OK - certainly doesn't leak or smell with about 15 litres in it.
Not sure how bad yours is but if it's easier or if yours is cream crackered I'm only in Sheffield so the one from my car parts could be a possibility. Let me know if you're interested anyway.
Re getting the tank out - I'm about to lift the body off the running gear on my parts car. not sure whether it's much easier than removing the transmission, but I think it'll mean not having to try to mess about with a jack lowering the trans (you leave it connected to the axles too. Might be an easier way to get to the tank. If I get there before you get your tank out I'll let you know how it goes.
Mike
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do.
1986 924S, White, donor car, part way through disassembly.
Old 05-03-2011, 11:14 PM
Did you fix your tank in the end? mine has a slight leak if I put more than 15litres in when the light's just come on. I can live with it, but it would be easier if I didn't have to fill up every 100 or so miles (and might be more frequent in Germany in a couple of weeks at autobahn speeds).
Was going to try chemical metal - was that one you tried?
Mike
Old 07-21-2011, 07:24 AM
No, I bought a special aircraft fuel tank sealant and reinforced the repair with woven fibreglass cloth. It costs £50+VAT+carriage though I must warn you. If you want the address just ask. I'll bet your leak is under the tank retaining strap-that's where they usually go. I was able to fix mine without even jacking the car up.
Old 07-22-2011, 02:07 AM
Forgot to say, it also takes 24 hours to cure, and I then applied a seond coat plus fibreglass cloth
Old 07-22-2011, 02:09 AM
Yep, that's exactly where it's gone. The underseal can be scraped off with just your finger. Where did you get it from? waiting 24 hours isn't much of a problem as I don't drive much, just running short of time as only have 2 weeks before going on holiday.
Mike
Old 07-22-2011, 06:01 AM
Tags
fuel tank
