speed and refrence sensors
So taking of my clutch cover I didn't fully remove my sensors and now they are broken. So I have looked on this forum on the parts section and I got a couple leads. But if anyone has the sensors if you can email me a call or text 5598366592. Any junk yard numbers I can call that might have the number would also be greatly appreciated.
Thank you |
:)^^ Without knowing your location peoples will have a hard time to guide you in the rigth direction.
If you are unable to find used...The BMW 1988 535i are an interchange.
I prefer the sensors with the metal cap on the bottom. The sensors with a black plastic cap are usually cheaper. BMW reference sensor part number-need parts - Rennlist Discussion Forums GL John |
I am out of lemoore California 30 min south of fresno. Area code 93245.
Thanks for the advice. Those sensors will also work on my 84 944 n/a |
A certain haus of autos in az has this part cheap. . .search for 0261210002.
Car-Part.com--Used Auto Parts Market
But first did you try to buy them here. Used ones are very brittle. |
Salvage parts not worth it in this instance. . .can easily cause a breakdown on the road.
