Greasy Member
many944s's Avatar
Lower end tick.... DONT let it go!!!
Hey all, with race season in full swing I dont get to post as often as I should, but I wanted everyone to see this even though it was a rare situation...
The story:
In the last 2 months I have seen two engines where a con-rod bearing has spun and welded the rod to the crank! The first engine was one we had never touched before on cyl #2, the most recent was an engine we built just 5 days before the "blow up" but it happened on cyl #3.
In each case the engine was turning at or near redline during a race. I cannot say anything for the first engine (that actually BLEW the rod and piston through the oil pan cracking the block and spiltting the girdle in two.
As for the second engine, it was completely blueprinted, all rods magnafluxed. All it took was a small debris cut in a radiator hose to drain the coolant system overheating the oil to spin the #3 bearing. From this point the rod cracked and punched the piston back up 180 degrees off hitting the valves on the non-reliefed side of the piston, cracking the piston and destroying the cylinder. Although every effort was put into this engine, it was a cut $18 hose that blew it all.
Long story short..
If you hear a new "tick" or "click" or "slap" other than lifters or injectors STOP and investigate!!
I hate posting these but enjoy::
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 08-01-2011, 02:25 PM
Proprietoristicly Refined
John_AZ's Avatar
WOW!
Were the engines in one of the rental track cars you have?
If it was, more excitement for the driver!
Thanks Nick
John
1988 924S, 80K ..+ 1987 924S, 150K DD (+15K est. bad odo)
Old 08-01-2011, 04:14 PM
one of gods prototypes
bell's Avatar
what was the temp gauge reading when the 2nd engine blew? could've probably saved it by turning it off........LOL
Brought to you by Carl's Jr.
Old 08-01-2011, 04:52 PM
Greasy Member
many944s's Avatar
Thankfully, the motor we built wasn't in a rental car. It was however in one of our arrive and drive racers' car
Thankfully the debris cut in the rad hose was VERY obvious... It was sad though since the engine was setting some awesome lap times all day before the hose was cut!!
Fortunately as a shop owner & car/engine builder there is nothing I can do about track crap hitting a hose at 100+ mph thrashing an awesome engine... The best I can do (which is what Im currently doing) is build a new engine for the driver for the cost of parts with no labor charge.
--Note: this is not a primer for anyone running our engines to cut a hose for a discount rebuild
Just wanted to post this as a warning for anyone who has noticed a lower end noise as it is not something to be taken lightly! Though, I would hope most DD drivers aren't running their cars at 6300rpm on each shift around town though who am I to judge
-Nick
Old 08-01-2011, 07:03 PM
bell's Avatar
just curious......what was the time frame of the elevated temp til destruction? not being a smartass, just have done this before and there was plenty of warning which i ignored (and paid for LOL)
Old 08-01-2011, 07:11 PM
Greasy Member
many944s's Avatar
There's very few people I call smart ass... My 5yo daughter is the primary one
There was almost no warning at all (considering it was @ track speed) the driver (who is extremely competent) said he felt a slight power drop a couple of corners before the blow-up. shortly after the power drop the temp started to go up VERY QUICKLY, then.. well.. the final outcome
Of all the drivers I sponsor, I put %100 confidence into the skills of this guy! He knows how to check his gauges in every straight when he isnt fighting traffic (kudos to you Neal if your reading )
I probably shouldn't say this, but... he WAS driving both of the cars that had this failure. I'm just going to chalk it up to his ability to almost never trail brake and feather his clutch and throttle to an AMAZING extent. I drove open wheel for a long time, and I would be willing to bet he would give me one HELL of a run for my $$ in a FF, F500, or even F5000!!!
"Ok Neal, here's your chance to gloat"
-Nick
Old 08-01-2011, 07:45 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Send out that piston and have it rebuilt - lol
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 08-01-2011, 08:02 PM
Greasy Member
many944s's Avatar
Rebuilt hell, this is the race world....
"It will buff right out"
-Nick
Old 08-01-2011, 08:08 PM
CorsePerVita's Avatar
It's cool, slap some JB weld on it, it'll be fine. Hee hawwwwwwww
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 08-01-2011, 08:30 PM
Greasy Member
many944s's Avatar
****... JB weld!! Didnt even think of that!
I'll have to try that
-Nick
Old 08-01-2011, 08:34 PM
Hahaha! If only it were that simple eh? haha.
That's a pretty epic failure!
Old 08-01-2011, 08:37 PM
Greasy Member
many944s's Avatar
Actually, that was a "soft" failure... I'll try to post pics tomorrow of the engine that "BLEW" the whole side of the block & pan out!!!
Old 08-01-2011, 08:46 PM
That would be interesting to see!
Old 08-01-2011, 08:52 PM
Garage Helper
Oh, OK - Time to get out the duct tape. You will also have to double check for leaks.
Once had a 3 cylinder that ran for two weeks. Blew the No. 2 piston and rod through the side of the block. Put a strap of leather and hose clamps on the crank to hold a little oil pressure and with a patch of tin with Gorilla Glue kept oil in the motor block hole. I would start it and at low RPM's it ran so rough...would settle out a little at higher RPM's.
Old 08-02-2011, 01:47 AM
bell's Avatar
thanks for the explanation......i too will take some pics of one we have in the shop which met a similar fate......knife edged crank....GIANT hole and many many fragmented bits LOL
Old 08-02-2011, 07:54 PM
meister member
speedracing944's Avatar
Sorry to hear about the failure.
I have a couple extra pistons in my old block.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-02-2011, 08:33 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
